On – Enables or disables the hot/dark spot effect. Multiplier – Specifies a multiplier for the brightness of the hot/dark spot. Hot Spot – Controls how the hot/dark spot is applied to the Softbox texture. See the Hot Spot vs Dark Spot example below. Add – The color is added to the texture, adding brightness and creating a hot spot. Subtract – The color is subtracted from the texture, removing brightness and creating a dark spot. Tint On – When enabled, allows the user to control the color of the hot spot. Tint Color – Specifies the color of the hot spot. Tint Strength – Specifies a multiplier that controls the strength of the Tint Color. |
