Sun – Creates a connection between a VRaySun and the VRaySky object to calculate its appearance. Overwrite Sun Settings – Overwrites the VRaySun Settings that would otherwise be taken from the Sun node. This is useful when using the VRaySky without a Sun node. Intensity Multiplier – Determines the intensity value when overwriting the sun settings. Size Multiplier – Controls the visible size of the sun. This affects the appearance of the sun disc as seen by the camera and reflections, as well as the blurriness of the sun shadows. Turbidity – Determines the amount of dust in the air and affects the color of the sun and sky. Smaller values produce a clear and blue sky and sun as you get in the country, while larger values make them yellow and orange as, for example, in a big city. Ozone – Affects the color of the sun light. Available in the range between 0.0 and 1.0. Smaller values make the sunlight more yellow, larger values make it blue. Sky Model – Determines the procedural model that will be used to generate the VRaySky texture: Hosek et al – When selected, the VRaySky procedural texture is generated based on the Hosek et al. method and uses a different ground and sky gradient. Preetham et al. – When selected, the VRaySky procedural texture is generated based on the Preetham et al. method. CIE Clear – When selected, the VRaySky procedural texture is generated based on the CIE method for clear sky. CIE Overcast – When selected, the VRaySky procedural texture is generated based on the CIE method for cloudy sky. PRG Clear Sky – The VRaySky procedural texture is generated based on the Improved method which has enhanced sunrise and sunset sky. See the Improved Sun and Sky courseware page for more information. Horizontal Illumination – Specifies the intensity (in lx) of the illumination on horizontal surfaces coming from the sky. Note: Only available when CIE Overcast or CIE Clear are selected as the Sky model. Filter Color – Shifts the hue of the V-Ray Sun and Sky system towards the color specified in the field. Ground Albedo – Sets the color of the V-Ray Sun and Sky system's ground. Blend Angle – Specifies the angle in degrees where blending will occur between the horizon line and sky. Values close to 0.0 produce a sharper horizon line, while larger values produce a softer horizon line. Horizon Offset – Allows the user to manually lower the horizon line. |
