Clouds On – Enables the cloud system. Ground Shadows – When disabled, the entire scene is covered by a single shadow or fully illuminated depending on whether the sun is blocked by a cloud at the current camera position. This is useful for smaller scenes and speeds up the rendering process. When enabled, V-Ray calculates the shadows precisely at every point of the scene. This provides a lot more definition to the shadows but may slow down the rendering process. It is helpful in larger scenes where the effect of the clouds is more visible. See the Ground Shadows example below for more information. Density – Controls the density of the cumulus and stratus types of clouds. A value of 1 fills up the sky with clouds. See the Density example below for more information. Density Multiplier – A multiplier to the Density parameter. The larger the value, the darker the sky becomes at the horizon. Setting a value of 0 results in no clouds, regardless of the Density value. Variety – Controls the variety of the cumulus and stratus types of clouds. See the Variety example below for more information. Seed – Generates a random value, based on the given number, to change the pattern of the clouds and the contrails. Cirrus Amount – The maximum value of 1 fills the sky with cirrus clouds. Decreasing the value, lowers the presence of such clouds. When set to 0, the cirrus clouds are completely gone. See the Cirrus Amount example below for more information. Longitude Offset (m) – Moves the cloud system along the longitude. For more information, see the Longitude and Latitude Offset example below. Latitude Offset (m) – Moves the cloud system along the latitude. For more information, see the Longitude and Latitude Offset example below. Height (m) – Specifies the cloud position in height. For more information, see the Height example below. Thickness (m) – Lower values make the cumulus and stratus types of clouds thin and sheer/lucent, while higher values make them full and heavy. For more information, see the Thickness example below. Longitude Phase (%) – Controls the phase by longitude and it can be used to fine-tweak the cumulus and stratus clouds appearance. The appearance of the clouds loops at 0, 100, 200, etc. This parameter can be animated to resemble natural clouds appearance. Latitude Phase (%) – Controls the phase by latitude and it can be fine-tweak the cumulus and stratus clouds appearance. The appearance of the clouds loops at 0, 100, 200, etc. This parameter can be animated to resemble natural clouds appearance. Enable Contrails – When enabled, plane contrails are simulated in the sky. Number of Contrails – Determines the number of contrails generated. See the Number of Contrails example below for more information. Contrails Strength – Determines the opacity of the contrails. Lower values create less opaque trails, which look older. See the Contrails Strength example below for more information. Contrails Distortion – Determines the amount of distortion in the contrails. See the Contrails Distortion example below for more details. Contrails Offset Long. (m) – Offsets the contrails by a given value, according to the X axis. See the Contrails Offset example below for more information. Contrails Offset Lat. (m) – Offsets the contrails by a given value, according to the Y axis. See the Contrails Offset example below for more information. Contrails Time – Determines how far the contrails progress along the sky. See the Contrails time animation below for more details. |
