Enabled – Turns the light on and off. Toggle Target – Switches the light between being targeted and not targeted (free light). The Maya default "t" hotkey can also be used. IES File Name – Load an .ies file to use for the current light. Color Mode – Chose the mode in which the color of the light will be specified. Light Color – When Color Mode is set to Color, controls the color of the light. When using photometric units, this color is normalized so that only the color hue is used, whereas the light intensity is determined by the Intensity parameter. Temperature – When Color Mode is set to Temperature, this parameter controls the color of the light. Filter color – A color multiplier for the light. Intensity – An intensity multiplier of the light. |
