This page describes the various Extra V-Ray Attributes available in V-Ray for Maya and provides links to documentation for these features.
V-Ray for Maya provides a number of extra attributes for controlling various aspects of the scene and rendering process. These attributes enhance existing V-Ray scene elements by providing additional controls.
Scene Objects
Mesh Attributes
Affects polygonal objects, mostly as render-time effects rather than affecting the actual geometry. Click here to find out more.
NURBS Surface Attributes
Control the conversion of a NURBS object to a mesh at render time to increase rendering speed or conserve memory. Click here to find out more.
Particle Attributes
Adds parameters for Maya particle systems. Click here to find out more.
Transform Attributes
Provides a few extra parameters for an object, such as excluding it from rendering. Click here to find out more.
Lights and Cameras
Camera Attributes
Can turn the virtual camera into many types of real-world cameras, and provides familiar camera controls such as shutter speed. Click here to find out more.
Lights Attributes
Allows V-Ray properties to be applied to some or all Maya native lights in the scene. Includes Light Attributes and Decay Attributes. Click here to find out more.
Materials and Shading
Shading Group Attributes
Provides the ability to override material settings. Click here to find out more.
Texture Attributes
Can be added to various texture-related nodes to control export or the textures themselves. Click here to find out more.
Material Attributes
Provides additional controls to both Maya and V-Ray materials. Click here to find out more.
Misc.
Fluid Attributes
Adds extra control for Maya fluids. Click here to find out more.
Hair Attributes
Provides parameters to optimize Maya hair for rendering with V-Ray. Click here to find out more.
Bifrost Attributes
Adds controls for Bifrost simulations. Click here to find out more.
Placement Attributes
Adds controls to 2D Placement and 3D placement nodes. Click here to find out more.
Surface Luminance
Attributes adds controls to Maya's Surface Luminance node. Click here to find out more.
Custom Attributes From Text Files
The extra prefix attributes are a set of three text (.txt) files containing key-value definitions, which can be used to add dynamic attributes to Maya, V-Ray or 3rd party nodes. The default set of files, which are shipped with the installation are located inside the scripts folder of the V-Ray for Maya installation. It is possible to supply a custom set of attribute files. V-Ray will use the paths, specified by the VRAY_FOR_MAYA_SHADERS environment variable to search for such custom files. The default attribute files can be used as an example but should not be modified.
The dynamic attributes appear in the Attributes menu of the Attribute Editor and can be added using this menu or by calling the available command: "vray addAttributesFromGroup".
The custom attribute files should have the following names:
# <prefix>_attributes.txt
Contains all dynamic attribute definitions. Each definition includes the attribute's label, its type, its group, its default value, its range of values, as well as other keys. One or more attributes belong to a group, which can then be assigned to a node. The <prefix> must be the same as all attributes' and groups' prefixes.
# <prefix>_attributeGroups.txt
Contains all attribute group definitions. Each definition includes its label and a list of existing attributes from <prefix>_attributes.txt. An attribute key format is "attribute_n", where n must be a consecutive number, starting from 0. The attribute groups can then be assigned to a node. The <prefix> must be the same as all attributes' and groups' prefixes.
# <prefix>_attributeNodes.txt
Contains node definitions, which link existing nodes to attribute groups. Each node definition is a list of existing groups from <prefix>_attributeGroups.txt. A group key format is "group_n", where n must be a consecutive number, starting from 0.
The word "vray" should not be used as a prefix, as it is a reserved word.
Keys defining attributes in <prefix>_attributes.txt
# label
The label of the attribute, which is shown in the UI, next to the attribute control.
# state
It can be either "optional" or "required". Attributes with specific states can be fetched with "vray getRequiredAttrs" and "vray getOptionalAttrs" commands.
# group
The name of the group as defined in <prefix>_attributeGroups.txt, to which the attribute belongs.
# subtype
The subtype of the attribute. Every decl type supports specific subtypes. For details see # decl.
- button: A button control.
- switch: A checkbox control.
- selector: An option menu control.
- slider: A slider control.
- materialConnection: A control for connecting materials.
- textureConnection: A control for connecting textures.
- file: A file text control with a browse button.
- buttonWide_cmd: A button, which executes a mel function. The function name should be assigned to the "default" key.
- text_label: A text label.
- separator: A separator with a text, specified by the "label" key.
- ctexture: Adds a shader connection button.
- cvector: Makes the attribute children x, y, z, instead of r, g, b.
# decl
The type of the attribute. It can have one of the following values:
- float - A floating point number. Supports button, switch, selector, textureConnection and slider subtypes. Defaults to slider.
- int - An integer number. Supports button, switch, selector, textureConnection and slider subtypes. Defaults to slider.
- bool - A boolean. Supports button, switch, selector, textureConnection and slider subtypes. Defaults to slider.
- distance - A floating point number. Supports button, switch, selector, textureConnection and slider subtypes. Defaults to slider.
- color - A color. Supports ctexture and cvector subtypes.
- float[3] - A triple float. Supports cvector, materialConnection and textureConnection sybtypes.
- string - A string. Supports selector, file, buttonWide_cmd, text_label and separator subtypes.
# range_min
The minimum value an attribute can have.
# range_max
The maximum value an attribute can have.
# rangesoft_min
A soft minimum limiting only the control UI.
# rangesoft_max
A soft maximum limiting only the control UI.
# range_step
The minimum value with which an attribute value can be changed.
# range_(n)
Used with selector subtypes, where n is a consecutive number starting from 0 to define a list of fixed possible values. The even n values (range_0, range_2, etc.) describe the item labels, while the odd ones describe the item values.
# default
The default value of the attribute.
# hidemap
When set to 1, the map button of the attribute control will not be shown.
Examples
Example of an attribute definition in an example someprefix_attributes.txt file:
Attribute someprefixCameraDistance {
  label = Distance
  state = optional
  group = someprefix_camera
  decl = float
  subtype = slider
  range_min = 0.0
  range_max = 1000.0
  rangesoft_min = 1.0
  rangesoft_max = 100.0
  range_step = 0.01
  default = 1.0
  hidemap = 1
Example of an attribute group definition in an example someprefix_attributeGroups.txt file:
AttributeGroup someprefix_camera {
  label = Camera
  attribute_0 = someprefixCameraDistance
Example of a definition, which links a node to a list of groups in an example someprefix_attributeNodes.txt file:
Node VRayMtl {
  group_0 = someprefix_camera
