This page describes the VRayRenderableCurve node and its use.
In the scene below, a VRayRenderableCurves node is used to create the effect of draped cables.
The Tessellation parameter affects the number of line segments that are used when approximating the curves. Smaller values use more line segments to approximate the curve, producing smoother results but slower rendering.
