This page describes the ply2vrmesh command-line utility.
The ply2vrmesh command-line utility can convert .ply, .obj, .bin, .geo, .bgeo, .hclassic, .bhclassic, .abc and .vrscene files to .vrmesh files for rendering with V-Ray through V-Ray Proxy Objects.
UI Paths
Windows
C:\Program Files\Chaos\V-Ray\Maya 20xx for x64\vray\bin\ply2vrmesh.exe
Linux/usr/Chaos/V-Ray/Maya 20xx-x64/vray/bin/ply2vrmesh
macOS/Applications/Chaos/V-Ray/Maya20xx/vray/VRay.app/Contents/MacOS/ply2vrmesh
  • The converter works with most of the popular .ply formats, both ASCII and binary, big-endian, or little-endian.
  • In addition to the geometric data (faces and vertices), the converter recognizes some of the most common additional channels such as diffuse surface color. Vertex colors are recognized if they are specified as "red", "green", and "blue" or "diffuse_red", "diffuse_green", and "diffuse_blue" vertex properties.
