This page gives information about the VRScansPMask Element Render Element.
VRScansPMask Element render element allows color changes to a V-Ray Scanned Material in compositing.
||Render Setup window||  > Render Elements  tab  > Add  button  > VRScansPMask Element
VrayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Color mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Setup window to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise –  Specifies whether to denoise this render element.
