Although the TexSampler node does not contain any inputs, it provides a wide variety of outputs. point – The sampled point. pointReference – The shading point in reference space. pointObject/Camera – The sampled point in object/camera space. normal – The surface normal for the sampled point. normalReferece – The smooth normal in reference space. normalCamera/Object – The surface normal for the sampled point in object/camera space. bumpNormal – The bump normal for the sampled point. bumpNormalCamera/Object – The bump normal for the sampled point in object/camera space. gnormal – The geometric normal for the sampled point. camToWorld – The transformation from camera to world space. view_dir – The view direction. frame_time – The current frame (image) time. ray_time – The ray time between the motion blur interval. facing_ratio – Returns a number between 0 and 1 that specifies if the sampled point is facing towards or away from the camera. material_id – The material ID for the sampled point. flipped_normal – Specifies which side of the surface is sampled. cameraNearClipPlane – The camera near clipping plane, calculated from the scene bounding box and the camera transform in the frame data. cameraFarClipPlane – The camera far clipping plane, calculated from the scene bounding box and the camera transform in the frame data. uvCoord – The UV coordinates for the sampled point. rayDirection – Returns a vector from the sampled point to the camera position. pixelCenter – The location of the pixel in the final rendered image that corresponds to the sampled point. tangentUCamera – The surface tangent in the U direction for the sampled point. tangentVCamera – The surface tangent in the V direction for the sampled point. ray_depth – The ray depth. path_length – The path length. object_id – Returns the object ID for the object at the sampled point. parent_object_id – Returns the object ID for the parent object of the sampled point. velocity – The velocity of the sampled point. speed – The speed of the sampled point. random_by_renderID – Allows random colors or textures to be assigned to several objects according to each object's render ID. random_by_polyShell – Allows random color or textures to be assigned to multiple polygon shells that have been combined into a single object. |
