The Glossiness Render Element stores the image's reflection glossiness as a grayscale image that represents the degree of Reflection Glossiness set for materials in the scene. White areas have the most reflection glossiness, while dark areas have little. The amount of reflection glossiness for a material is set by its Reflection Glossiness parameter. For example, the V-Ray Material has a Reflection Glossiness parameter, and the Skin Material has parameters for primary and secondary reflection glossiness. |
