This page provides information on the often used tools in V-Ray for Maya that can be found in the drop-down menu of V-Ray menu > Tools.
V-Ray Profiler
Analyze elements' render time in order to optimize your scene.
Create V-Ray PluginNode
V-Ray for Maya can create a node from any plugin that comes with the V-Ray installation.
Import V-Ray Material from File
V-Ray Material Importer tool is used to import any V-Ray material exported from a .vrscene file into Maya.
VRmat Converter
Converts materials in Maya to .vrmat files that can be loaded using the VRayVRmatMtl material.
Archive V-Ray Scene
Enables the export of a V-Ray scene as an archive, preserving the V-Ray render settings and assets.
Convert Scene for V-Ray
Opens the Convert Scene for V-Ray window where you can convert a material to a VRayMtl.
Migrate Legacy scenes
V-Ray automatically migrates a legacy scene to a V-Ray 5 compatible setup or this can be done manually.
Opacity Cutout
The Opacity Cutout tool converts low-poly opacity mapped objects to actual geometry cutouts.
Export Materials to USD
This option exports selected V-Ray materials to USD file(s).
Export Materials to MaterialX
This options exports V-Ray materials to MaterialX (.mtlx) file.
Check for Missing Cosmos Assets
V-Ray automatically detects and downloads missing Chaos Cosmos assets.
