Help make V-Ray even better Participate in the improvement decisions for future version of V-Ray. No intelligence property is violated when agreeing to participate in the feedback program. Chaos doesn't gather scenes, assets, materials, etc. What Chaos receives is user preferences on just a few key render settings and the resulting render times. The point of this feature is to improve V-Ray's performance and the user experience. For more information, see the Chaos Telemetry page.
V-Ray type The available installation types are: Workstation – A full installation that includes V-Ray for Cinema 4D, IPR for Cinema 4D, V-Ray Standalone, V-Ray Tools. Standalone – An installation which includes V-Ray Standalone and IPR render server. Please choose this option if you plan to use this machine only for Distributed Rendering with V-Ray Standalone and an IPR render server. Add firewall exception – Enabling this option allows the default licensing port (TCP 30304) in the firewall. If you disable it at this step, you will need to manually add firewall exceptions later. Install Chaos Scatter – Enable this checkbox to install the Chaos Scatter plugin for Cinema 4D. Chaos Scatter is a powerful instancing tool, which allows you to populate large scenes, without reducing performance See more information on the Chaos Scatter page.
Directories Here you can specify the installation paths. Please check if the default folders are correct.
Licensing In this step, you can specify whether the V-Ray license server runs locally or on another machine. If you select the Remote option, you have to fill in the IP address of your V-Ray license server in the field Primary License Server. An Alternate License Server is used when the primary one does not respond. Please leave the port 30304 unchanged!
2. If you select the Local licensing option, you are presented with the Chaos License Server installation.
Chaos License Server Options At this step you can choose the license server directory. Migrate data during installation – When enabled, transfers all of your settings made with earlier versions of the License Server, such as enabled dongle subsystem, proxy settings, etc. When disabled, installs the License Server with all settings at their defaults and any custom settings from the previous installation are lost. Add firewall exception – When enabled, the default licensing port (TCP 30304) can pass the firewall. If you disable it at this step, you will need to manually add firewall exceptions later.
