This page gives information on the VRayLightMix render element.
If changes to the render element are made while the VFB is open, those changes are reflected after the VFB is closed and reopened. |
To set the LightMix for use:
Before rendering, set your lights to white (neutral) color and boost their intensity. Rendering with lower intensity and then increasing it from the LightMix might produce noise in your render. If this happens, use the "To Scene" option and re-render the scene. |
The LightMix allows changing the appearance of the image by controlling the lights in the scene even after the rendering is done.
In the example below, we've created two different light setups with the help of VRayLightMix: daylight and dusk. The Daylight appearance is achieved by using sunlight and an additional softlight to simulate light coming from the outside. The Dusk appearance is achieved by setting the sun Multiplier to 0, changing the color multiplier of the outside light to blue, increasing the intensity multiplier of all interior lights and tinting them with warmer colors (all ceiling and built-in furniture VRayLights), adjusting the self-illumination multiplier of desk and ceiling lights, shaded with VRayLightMtl.
