Official Release
Date – Mar. 8, 2017
DownloadBuild 3.40.01
Installation & Licensing
  • New streamlined installer combining installations for SketchUp 2015, 2016 and 2017
  • The license can now be activated or released in a floating license environment
  • New License Server introduces flexible licensing for all Chaos Group products, without the need for any physical devices to be plugged into your machine
User Interface
  • V-Ray Asset Editor - Manage settings, materials, lights and geometry in a single window
  • Updated V-Ray for SketchUp toolbar - Quick access to common features, and the V-Ray Asset Editor
  • GPU Device Selection tool added to the V-Ray Tools menu - Select which graphic card/s should be used for GPU accelerated rendering
  • Added Render, Render with V-Ray Interactive, Export V-Ray Scene File and Show VFB buttons to the Asset Editor
  • Improved V-Ray context menu in the host application, which allows shortcut key-binding through SketchUp
  • Implemented buttons for switching between basic and advanced parameters for various setting sections
  • Improved and re-organized light list and advanced light parameters editor
  • Improved and re-organized geometry list and advanced geometry parameters editor
  • Improved and re-organized Quick/Basic Rendering Settings section
  • Improved and re-organized Advanced Rendering Settings section
  • Implemented Save and Load V-Ray Settings from file buttons. Added Revert to default Render Settings button
  • Added easy to use interface for switching between Interactive, Progressive, and GPU based rendering
  • Improved Quality slider and quality preset values
  • Improved Camera Controls - Toggle between simple and advanced camera parameters
  • Added exposure value(EV) control
  • Added white balance control
  • Added a defocus slider and input value field - Change the defocus amount without altering camera exposure
  • Implemented Vertical Tilt control commonly used for perspective compensations
  • Improved Render Output roll-out interface
  • Improved render elements selection
  • Implemented Get View Aspect function in the UI - Automatically get the exact screen aspect ratio
  • Implemented Show Safe Frames function in the UI - See the exact render frame, and easily set camera positions
  • Improved Environment roll-out interface
  • Added easily accessible toggles for commonly used effects such as Material Override, GI, Caustics, and AA Filtering
  • Exposed Material Override functionality for easy access - Enable or disable the effect with a toggle
  • Exposed V-Ray Swarm functionality for easy access - Toggle the network resources usage, and change usage percentage with a slider
  • Added a V-Ray Swarm manager - Monitor network rendering jobs
  • Improved Material Library and Library UI
  • Implemented drag and drop functionality when adding a material from the library to the scene assets list
  • Added seven new Material Swatch Previews: Generic, Fabric, Floor, Ground, Subsurface Scattering, Wall and Wall Close-up
  • Implemented Purge unused materials function and a button
  • Improved material layer management, ordering, and naming
  • Improved tool-tips - Easily accessible, detailed information about the use and application of parameters and buttons
Improved Speed and Quality
  • A large number of render speed/performance optimizations were introduced
  • Implemented multi-threaded scene parsing
  • The Intel® Embree library is now integrated into V-Ray and boosts performance when rendering both static and dynamic geometry
  • Improved rendering performance for dynamic meshes, instances, V-Ray Fur and V-Ray Proxy objects
  • Implemented Variance Base Adaptive Sampler (VBAS) - It improves and balances the sampling adaptation in dark or bright areas of the image
V-Ray Swarm
  • Implemented V-Ray Swarm (previously Distributed Rendering)
  • Implemented the Swarm Manager - A web interface that lists all the machines used for rendering. It gives access to status and additional information about the distributed rendering process
  • Added Cap CPU Utilization toggle - Limit the utilization of the local machine CPU (to a maximum of one thread). Continue using your computer without noticeable slowdown, while the other Swarm nodes are rendering the image
Additional Improvements
  • Implemented a new Progressive Image Sampler - Render with the production engine in progressive mode
  • Implemented V-Ray Scene exporter (exports .vrscene files)
  • Implemented Probabilistic Lights optimization control
  • Added Max Ray Intensity optimization control
  • Implemented global minimum Shading Rate control
  • Implemented Dynamic Bucket Splitting - Dynamically decrease the bucket size in the final rendering stages
  • Light leak prevention added and enabled for the Light Cache (GI engine)
  • Created the Wipe Scene tool - Clean a model from the 3D Warehouse, or clear all V-Ray related data from a scene and start from scratch
Materials General
  • Implemented Material Presets system and Quick Setting interface
  • Drag and drop materials from the OS file browser and into the V-Ray Asset Editor
  • Drag and rearrange material layers for easy shader creation and management
  • Implemented ready-made V-Ray Material Library - Choose from more than 500 materials, organized in categories
  • Microfacet GTR / GGX BRDF added to the V-Ray Material options - With fine highlight control, this is ideal for shading metal and other reflective surfaces
  • Thumbnails are automatically saved when saving a material file ( .vrmat). Materials can then be visually identified in the OS file browser
  • Added the option to display any texture from a shading tree in the SketchUp viewport. The same texture can be used for SketchUp size modifications
  • Implemented texture helper to give full control over geometry UVs when using procedural V-Ray specific textures
New or improved materials
  • Improved Generic material (VRayMtl)
  • Added V-Ray Subsurface Scattering material
  • Added V-Ray Car Paint material
  • Added V-Ray Stochastic Flakes
  • Added V-Ray Override Material
  • Added V-Ray Bump Material
  • Added V-Ray Hair Material
  • Improved V-Ray Blend material
  • Improved Two-sided material
New or improved textures
  • Improved procedural textures UI, parameter arrangement and default values
  • Added ability to copy-paste or drag & drop texture maps and color values between different input slots
  • Added V-Ray Curvature map
  • Added V-Ray Edges Tex - Create wireframe rendering and a rounded corners effect
  • Added V-Ray MultiSubTex
  • Added V-Ray TriPlanar texture
  • Added Angle Blend
  • Added V-Ray Composite map
  • Added Tiles texture - Create procedural tile and brick patterns with random variations in color
  • Improved V-Ray Dirt
  • Improved Falloff
  • Improved Fresnel
  • Improved Noise
V-Ray Interactive Rendering
  • Improved performance and stability
  • Added support for the V-Ray Clipper objects and SketchUp section planes (treated as clippers)
  • Added support for the V-Ray Material anisotropy effect
  • Added support for V-Ray Fur
  • Added support for the V-Ray Infinite Plane
  • Added support for textured IOR of the V-Ray Material
V-Ray GPU Acceleration
  • The CUDA engine supports and is optimized for Fermi-, Kepler-, Maxwell- and Pascal- based NVIDIA cards
  • Added support for Light Cache GI and Irradiance Map loaded from file
  • Improved support for big number of material effects and procedural textures
  • Implemented Coherent Tracing, which improves rendering performance
  • Implemented QMC sampling, which improves rendering performance
  • Added support for displacement
  • Added support for anisotropic highlights and reflections
  • Added support for layered material transparency
V-Ray Stereoscopic Rendering
  • Implemented One-Click VR Cubemap and VR Spherical Panorama stereo rendering. This is a hard-coded way of rendering dual camera stereoscopic images for use with preferred VR headsets
V-Ray Proxy
  • Added support for Alembic 1.5 ( .abc) files
Environmental Effects
  • Implemented Aerial Perspective atmospheric effect
  • Added support for the SketchUp viewport fog, using the Aerial Perspective effect
V-Ray Sun & Sky System
  • Added a new sky model - Hosek et al
  • Added ground color parameter - Ground Albedo
  • Added Blend Angle and Horizon Offset parameters
V-Ray Mesh Light
  • Implemented V-Ray Mesh Light - convert any geometry to a light source
  • All the Mesh Lights in the scene can be found in the Lights list for easy access and control
  • The V-Ray Mesh Light automatically becomes a component and can be copied as component in the SketchUp scene
Rectangle Light
  • Improved rendering performance with area lights
  • Implemented Shape parameter that lets you change the light shape to Ellipse
  • When creating a rectangle light one can set the direction by holding down the Shift key
Spot Light
  • When creating a Spot Light one can set the direction by holding down the Shift key. Cone size and Penumbra Angle can be controlled as well
  • Added support for bitmap textures and texture projections for the Spot Light
Sphere Light
V-Ray Dome Light
  • Implemented a function to control the Dome Light orientation by rotating the scene gizmo
Light Intensity Tool
  • Implemented Light Intensity Tool for adjusting light intensity in the viewport of SketchUp. Click-dragging up or down over a light will change its intensity
V-Ray Clipper
  • Implemented V-Ray Clipper
  • Added support for native SketchUp Section Planes, handled and displayed in the interface as a V-Ray Clipper
  • Added support for nested/grouped Section Planes and Clipper meshes
  • Added ability to clip with custom meshes
  • Added support for Section Plane visibility. Layer visibility can also be used
V-Ray Fur
  • Implemented V-Ray Fur
  • A SketchUp component will be created with the fur object
  • The V-Ray Fur can use the material of the base geometry, component or group
V-Ray Render Elements
  • Added Extra Texture render element. This produces an element with a single texture applied to all objects in the scene. The input texture can be a bitmap or a procedural texture such as V-Ray Dirt or V-Ray Curvature.
  • Added a Z-Depth render element, which provides information about object distance from the camera in the current view. Objects between the furthest and nearest points are rendered in varying shades of gray.
  • Added V-Ray Denoiser (as a render element). The V-Ray Denoiser takes an existing render and applies a denoising operation to it after the image is completely rendered. The denoising operation detects areas with noise and smooths them out
  • Added Object ID render element. The IDs can be determined based on groups and components
V-Ray Frame Buffer
  • Added the option to automatically save each render in the history (enabled from the VFB history options dialog)
  • The 1-9 keyboard keys can be used to switch between recent images saved in the VFB history
  • Added new color correction controls - Contrast & Highlight Burn, HSL, Color Balance, White balance, and Background image
  • Implemented Save and Load color correction functions
  • Added the ability Apply color corrections when saving to file
  • Added the ability to load arbitrary image file formats in the V-Ray VFB for post-processing
  • Deleting an image from the VFB history now sends it to the Recycle Bin
  • The History and Color Corrections toolbars can be docked to the VFB
  • Added ability to save multi-channel Open EXR and V-Ray Image files directly from VFB
  • Support for Open Color IO color corrections
  • Added an option for loading image files as VFB background or foreground layers
  • LUT ( .cube) files can be generated and saved based on color corrections set in the VFB > Lens effects can be applied directly in the VFB
