This page includes details on the items available from the main V-Ray menu in the SketchUp interface.
This submenu is only visible when right-clicking on a group or component and contains the tools to set/change and remove an Object ID number.
UV Tools Context Submenu
This submenu is only visible when right-clicking on an object with textured material already assigned to it. When used, the textured material gets projected to each geometry face, not the object itself.
1 – When applying Spherical projection only to specific parts of an object, its mapping may appear incorrectly.
2 - When you use the Pack Project option, a pop-up message appears that asks you whether or not to pack Cosmos asset files with the project.
