Some parameters are only available in Advanced mode. Mode – Specifies one of the following methods for adjusting textures. Multiply – Multipliers can be specified to adjust colors and textures. Blend Amount – Blend amounts can be specified to adjust colors and textures. Overall Color – Controls the intensity of the Overall Color, which acts as a color multiplier for all color components in the material. Transparency – Controls the intensity of the Transparency. Diffuse Color – Controls the intensity of the diffuse component color of the shader. Primary Spec. Color – Controls the intensity of the Primary Specular color component, which corresponds to the light reflected off the outer surface of the hair strands. Secondary Spec. Color – Controls the intensity of the Secondary Specular color component, which corresponds to the light reflected off the back surface of the hair strands. Transmission Color – Controls the intensity of the Transmission color component, which corresponds to the light that passes through the hair strands. |
