This section contains details about Utility Textures found in V-Ray for SketchUp
Utility Textures allow users to perform a variety of helpful functions on texture maps inside a scene (such as compositing textures together and value conversions), as well as provide color corrections option.
A Utility Texture can be replaced with another Utility Texture or any other type of V-Ray texture via the Replace With New Texture () button, which activates when you select the texture to be replaced. If the texture is an instance, all copies are changed as well.
In V-Ray 7, the Simple Mix, Mix (Value), Mix (Operator) and Mix (Map) textures are no longer available. They are replaced by the Layered texture.
