This section contains links to 3D Textures found in V-Ray for SketchUp.
V-Ray for SketchUp offers a number of 3D Textures specifically for use with V-Ray. Some of the textures are useful in mimicking real-life surface variety - such as Marble, Granite, Rock, and others provide different noise variations.
A 3D Texture can be replaced with another 3D Texture or any other type of V-Ray texture via the Replace With New Texture (
) button, which activates when you select the texture to be replaced. If the texture is an instance, all copies are changed as well.
