Animation – Enables the rendering of animated sequences. Time Segment – Specifies whether the entire animation or only a subset are rendered as individual frames. Entire Animation – Renders the entire animation as individual frames. Frame Range – Allows selection of only certain frames to be rendered. Start – Allows to render a subset of the animation as opposed to render the entire sequence. Value is expressed in "frames". End – Allows to render a subset of the animation as opposed to render the entire sequence. Value is expressed in "frames". Get Animation Range – Sets the frame-range to match the current project animation length. Motion Blur – Turns on motion blur sampling. Camera Motion Blur – When enabled, it considers the camera movement when calculating the motion blur effect. Otherwise, only objects in motion are blurred. Note that only proxy scene or mesh references can introduce object animation. |
