This page describes the ply2vrmesh command-line utility.
The ply2vrmesh command-line utility can convert .ply, .obj, .bin, .geo, .bgeo, .hclassic, .bhclassic, .abc, and .vrscene files to .vrmesh files for rendering with V-Ray through V-Ray Proxy Objects.
Installation
WindowsC:\Program Files\Chaos\V-Ray\V-Ray for SketchUp\extension\vray\bin
macOS
/Applications/Chaos/V-Ray/V-Ray for SketchUp/extension/vray/bin
For versions prior to V-Ray 7, the default locations are:
Windows: C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\vrayappsdk\bin
macOS: /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/vrayappsdk/bin
  • The converter works with most of the popular .ply formats, both ASCII and binary, big-endian, or little-endian.
  • In addition to the geometric data (faces and vertices), the converter recognizes some of the most common additional channels such as diffuse surface color. Vertex colors are recognized if they are specified as "red", "green", and "blue" or "diffuse_red", "diffuse_green", and "diffuse_blue" vertex properties.
