This page introduces V-Ray User Interface topics. Click on the appropriate topic(s) below for the full documentation and proper usage information.
V-Ray rendering plug-in for Rhino consists of the following:
V-Ray Toolbar
V-Ray Toolbar includes several toolbars with easy shortcuts to some of the most commonly used V-Ray components.
V-Ray Asset Editor
V-Ray Asset Editor allows for convenient management of V-Ray related assets and V-Ray render settings.
V-Ray Frame Buffer
V-Ray Frame Buffer contains a variety of additional rendering tools.
V-Ray Color Picker
V-Ray Color Picker is a color manager that allows numeric color value selection in Screen (sRGB) and Rendering (RGB) Color spaces.
V-Ray File Path Editor
Editor V-Ray File Path Editor is a file managing tool that lets you set file paths, create scene archives, and keep track of different assets.
V-Ray Menu
V-Ray menu provides access to most common V-Ray actions such as File Path Editor and Colorize Textures.
V-Ray Commands in Rhino
V-Ray for Rhino has a number of set commands executable through the main Rhino Command window.
Object Properties Panel
Rhino Object Properties panel offers some V-Ray functionalities.
V-Ray Log Window
The V-Ray Log Window collects and displays messages from the Asset Editor.
  • Hovering with the cursor over each color box in the Asset Editor displays a tooltip with the color value in RGB format with a range of 0 to 1 in Screen (sRGB) color space.
