UI | Native name | V-Ray plugin Name (plugin/parameter) | Support |
VRayMtl | BRDFVRayMtl |
| | diffuse | |
Diffuse Texture | diffuse | |
Roughness | roughness | |
Roughness Texture | roughness | |
Preset | - | |
Enable Bump map | - | |
Bump amount | bump_amount | |
Bump Texture | bump_tex | |
| Reflect | reflect | |
Reflect Texture | reflect | |
Reflect Glossiness | reflect_glossiness | |
Reflect Glossiness Texture | reflect_glossiness | |
Fresnel reflections | fresnel | |
Fresnel IOR | fresnel_ior | |
Fresnel IOR Lock | fresnel_ior_lock | |
Fresnel IOR Texture | fresnel_ior | |
Metalness | metalness | |
Metalness Texture | metalness | |
Max depth | reflect_depth | |
Reflect on back side | option_reflect_on_back | |
Dim distance | reflect_dim_distance | |
Dim fall off | reflect_dim_distance_falloff | |
Affect channel: Color only Color+alpha All Channels |
reflect_affect_alpha=0 reflect_affect_alpha=1 reflect_affect_alpha=2 | |
| Refract | refract | |
Refract Texture | refract | |
Refract Glossiness | refract_glossiness | |
Refract Glossiness Texture | refract_glossiness | |
IOR | refract_ior | |
IOR Texture | refract_ior | |
Abbe number | dispersion | |
Max depth | refract_depth | |
Affect shadows | refract_affect_shadows | |
refract_affect_alpha=0 refract_affect_alpha=1 refract_affect_alpha=2 | |
Thin-walled | refract_thin_walled | |
| None Volumetric SSS |
translucency=0 translucency=5 translucency=6 | |
Fog color / Scatter raduis | fog_color | |
Fog color Texture / Scatter radius Texture | fog_color_tex | |
Depth (cm) / Scale (cm) | fog_mult | |
Illumination: Uniform Directional |
Scatter color | translucency_color | |
Scatter color Texture | translucency_color | |
SSS amount | translucency_amount | |
| Self-Illumination | self_illumination | |
Self-IlluminationTexture | self_illumination | |
GI | self_illumination_gi | |
Mult | TexCombineColor / result_multiplier | |
Compensate camera exposure | compensate_camera_exposure | |
| Coat amount | coat_amount | |
Coat amount Texture | coat_amount | |
Coat glossiness | coat_glossiness | |
Coat glossiness Texture | coat_glossiness | |
Coat IOR | coat_ior | |
Coat IOR Texture | coat_ior | |
Coat color | coat_color | |
Coat color Texture | coat_color | |
Lock coat bump to base bump | coat_bump_lock | |
Enable Coat bump | - | |
Coat bump amount | coat_bump_amount | |
| coat_bump_map | |
| thin_film_thickness_max | |
| Sheen color | sheen_color | |
Sheen color Textures | sheen_color | |
Sheen glossiness | sheen_glossiness | |
Sheen glossiness Texture | sheen_glossiness | |
| BRDF: Phong Blinn Ward Microfacet GTR (GGX) |
brdf_type=0 brdf_type=1 brdf_type=2 brdf_type=4 | |
Use glossiness / Use roughness | option_use_roughness | |
GTR tail falloff | gtr_gamma | |
GTR tail falloff Texture | gtr_gamma | |
Anisotropy | anisotropy | |
Anisotropy Texture | anisotropy | |
Rotation | anisotropy_rotation | |
Rotation Texture | anisotropy_rotation | |
Local axis | anisotropy_axis | |
Map channel | anisotropy_derivation | |
| Trace reflections | reflect_trace | |
Trace refractions | refract_trace | |
Cutoff | option_cutoff | |
Env. priority | environment_priority | |
Preserve energy: RGB Monochrome |
option_energy_mode=0 option_energy_mode=1 | |
Double-sided | option_double_sided | |
Use irradiance map | option_use_irradiance_map | |
Fog system units scaling | fog_unit_scale_on | |
Effect ID | MtlMaterialID / material_id_number | |
Opacity mode: Normal Clip Stochastic |
opacity_mode=0 opacity_mode=1 opacity_mode=2 | |
| Diffuse Texture Multiplier | TexCombineColor / texture_multiplier | |
Reflect Texture Multiplier | TexCombineColor / texture_multiplier | |
Reflect Glossiness Texture Multiplier | TexCombineColor / texture_multiplier | |
Refract Texture Multiplier | TexCombineColor / texture_multiplier | |
Refract Glossiness Texture Multiplier | TexCombineColor / texture_multiplier | |
Opacity Texture Multiplier | TexCombineColor / texture_multiplier | |
Bump Texture Multiplier | bump_amount | |
Displace Texture Multiplier | TexCombineColor / texture_multiplier | |
Self -illum Texture Multiplier | TexCombineColor / texture_multiplier | |
Diff. rough Texture Multiplier | TexCombineColor / texture_multiplier | |
Fresnel IOR Texture Multiplier | TexCombineColor / texture_multiplier | |
Metalness Texture Multiplier | TexCombineColor / texture_multiplier | |
Anisotropy Texture Multiplier | TexCombineColor / texture_multiplier | |
An. rotation Texture Multiplier | TexCombineColor / texture_multiplier | |
GTR falloff Texture Multiplier | TexCombineColor / texture_multiplier | |
Coat amount Texture Multiplier | TexCombineColor / texture_multiplier | |
Coat gloss Texture Multiplier | TexCombineColor / texture_multiplier | |
Coat IOR Texture Multiplier | TexCombineColor / texture_multiplier | |
Coat color Texture Multiplier | TexCombineColor / texture_multiplier | |
Sheen color Texture Multiplier | TexCombineColor / texture_multiplier | |
Sheen gloss Texture Multiplier | TexCombineColor / texture_multiplier | |
Environment Texture | BRDFVRayMtl / environment_override | |
