This page outlines the usage of the built-in migration scripts for legacy scenes.
Some legacy options or features are deprecated and not fully compatible with V-Ray 5. The portal options for lights and the Linear Workflow option (previously found in the Color Mapping settings) are no longer compatible with V-Ray.
V-Ray 5 will detect if a scene uses these features and offer to automatically migrate the scene to a V-Ray 5 compatible setup.
You can select to not be prompted on scene open and instead run the migration manually from the V-Ray menu > Tools > Migrate Legacy Scenes.
The sections below explain in more detail what legacy features can be migrated and what the migration scripts do.
Options
Don't Show This Message Again On Scene Open – V-Ray will detect if opening an old scene contains any legacy features that can be migrated to a compatible setup. In this case, you will be prompted to run the migration. If you choose not to be prompted on scene open, you can manually run the migration from the V-Ray menu > Tools > Migrate Legacy Scenes.
Apply – Runs the migration for all legacy features.
Close – Closes the prompt window without running the migration.
Light Portals
The portal options for lights are not compatible with many new features like Adaptive Lights and Light Mix.
The legacy Light Portal migration will replace Portal Lights with the Adaptive Dome and make sure that Light Cache is used for GI and the Adaptive Lights option is enabled. This ensures faster and more accurate IBL lighting.
The migration script will roughly do the following:
Linear Workflow
Historically, the legacy Linear Workflow option provided a one-click workflow for proper gamma correction of textures. However, Maya comes with an advanced and powerful Color Management System that is more capable than the Linear Workflow option to ensure proper correction of input textures against multiple color spaces and is the recommended approach.
The migration script will attempt to convert the scene from both legacy features. In case just one feature is used, only that part of the script will be executed.
V-Ray will display a message if the migration is successful.
