This page shows where to find the Chaos Group product version.
Your V-Ray for 3ds Max version can be found in the Render Settings menu, under the Settings > About V-Ray rollout.
Your V-Ray for SketchUp version can be found under the Extensions > V-Ray > Help > About menu.
Your V-Ray for Maya version can be found under the V-Ray > About V-Ray toolbar menu.
Your V-Ray for Rhino version can be found under the V-Ray > Help > About V-Ray menu.
Use the command “version” to display your Chaos Cloud version.
version |
Your V-Ray for Revit version can be found under the V-Ray > Help > About menu.
Your V-Ray for Cinema 4D version can be found under the V-Ray> Help> About.
When V-Ray for Houdini is launched, its version is printed in the Houdini Console.
Your V-Ray for Modo version can be found under the V-Ray > Open Event Log menu
Your V-Ray for Nuke version can be found in the Nuke Console window.
Your V-Ray for Katana version can be found in the Render Log window.
Your V-Ray for Unreal version can be found under Edit > Plugins > Chaos Software.
Your V-Ray for Blender version can be found under File > User Preferences > Add-ons.
Use the command “-version” to display your V-Ray Standalone version.
version |
Phoenix for 3ds Max version can be found in 3ds Max Command Panel > Modify > Simulation rollout > About.
PhoenixFD simulator must be selected. |
Phoenix for Maya version can be found in Maya > Phoenix FD menu > About Phoenix FD.
Pdplayer version can be found in the Pdplayer startup window.
