This page provides information about the V-Ray C4DBake utility texture.
VRayC4DBake is a utility texture that helps you render native Cinema 4D textures with V-Ray with greater quality.
V-Ray does not support natively Cinema 4D textures and sometimes they might lack the needed detail.
For greater control over the quality, use the VRayC4DBake texture.
Workflow
  1. Create a V-Ray material and assign it to the object.
  2. Select the VRayC4DBake texture from the Texture slot.
  3. Go to the VRayC4DBake parameters and from the Shader options, select the Cinema 4D texture.
General
Pixels Type –
Width/Height –
Shader –
Properties
Filter Type –
Filter Blur –
Transfer Function –
Gamma –
Allow Negative Colors –
Interpolation –
