This page provides information about the V-Ray C4DBake utility texture.
VRayC4DBake is a utility texture that helps you render native Cinema 4D textures with V-Ray with greater quality.
V-Ray does not support natively Cinema 4D textures and sometimes they might lack the needed detail.
For greater control over the quality, use the VRayC4DBake texture.
Pixels Type – Specifies how to bake the pixel of the texture:
8-bit RGBAFloat RGBA8-bit RGBFloat Grayscale8-bit Grayscale
Width/Height – Specifies the resolution of the baked texture.
Shader – Specifies the Cinema 4D texture you want to render.
Filter Type –
Filter Blur –
Transfer Function –
Gamma –
Allow Negative Colors –
Interpolation –
