Official Release
Date - Dec. 9, 2021
V-Ray
V-Ray
V-Ray
Export
VRScene
V-Ray Fur
V-Ray Deadline
V-Ray
Export
OSL
Rendering
IPR
GPU
UI
Official Release
Date - June 17, 2021
V-Ray
V-Ray
Textures
Export
Rendering
OSL
UI
V-Ray
V-Ray GPU
IPR
Install
Export
V-Ray Proxy
Chaos Cloud
VRScene
Chaos Cosmos
AOVs
OSX
Official Release
Date - Nov. 17, 2020
V-Ray
Support for rendering in ACEScg color space with option to recognize the texture color space from the file name
Updated the V-Ray for Houdini installer so the V-Ray Material Library can be automatically set up in Houdini
Added the V-Ray Material Library (Windows only)
Added support for Post-Translate scripts in V-Ray 5 for Houdini
Simplified Renderer ROP UI
Added support for the V-Ray Memory Tracker
V-Ray GPU
VFB
Materials
Textures
Lights
V-Ray
V-Ray Proxy
Materials
Textures
Added support for the "Reference Space" and "Reference Transform" options for the TriPlanar texture for world-space projections
Added the "Random" and "Pattern ID" textures for V-Ray 5
Rendering
Export
Added support for selecting subnetwork in the Light Select's "Lights" list
Improved export time for instances with motion blur
Added support for V-Ray Object Properties placed over a Geometry node holding a VRScene SOP
Added support for exporting UV sets from unpacked alembic files even if the attribute type info is not "texturecoord"
Baking
Material Library
V-Ray
V-Ray GPU
Fixed a CUDA crash on Linux
Fixed a bug causing displacement to fail when rendering with CUDA or RTX
Fixed a bug causing attributes on particles to be ignored for shading
IPR
Fixed an IPR crash after production rendering
Fixed an IPR crash when starting IPR on frames other than 1
Fixed an IPR crash when changing the timeline frame during IPR
Fixed a bug causing IPR to halt when changing a parameter on the new Car Paint 2 material
VFB
Fixed a bug causing inaccurate Render Region in production rendering
Fixed a bug causing production renders to disable the history and clear the set up History folder path
Fixed "Use VFB Background Image" option under the Renderer ROP not working with the new VFB
V-Ray Proxy
Export
Fixed a bug causing double export for the lights in the Light Select element producing incorrect results
Fixed wrong parsing for Image File node's File Path parameter
Rendering
UI
VRScene
Cloud
Installer
Beta Release
Date - Sept. 16, 2020
New VFB
V-Ray
V-Ray Library
Materials
Textures
GPU
