The following page provides information on the plugininfo tool.
The plugininfo tool generates documentation for all V-Ray plugins. It can be used to list all V-Ray plugins or to display a detailed information for a specific one by using the commands from the Options table.
Note that plugininfo displays only core V-Ray plugin parameters. User data parameters are not listed.
User data parameters are employed in the communication between V-Ray for Rhino and its UI while the actual scene (V-ray core) parameters are set accordingly only at render time.
The precise names of such "user data" parameters can be found listed in exported V-Ray files:
Their parameter handlers contain isUserData="1"
To run the plugininfo tool its active directory needs to be changed to the V-Ray bin directory. A simple way to do it is by running the following line in command prompt:
cd "C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\vrayappsdk\bin" && "C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\tools\plugininfo.exe" |
The tool's options can be accessed using the following syntax:
plugininfo [ options ] -list [ <plugin name> ]
Lists all V-Ray plugins.
When <plugin name> is given, only plugins that match the given name are printed. Note that the wildcard symbol '*' is supported.
plugininfo [ options ] <plugin name>
Displays detailed description for the specified plugin - plugin id, location, supported interfaces, parameters, their types, default values, description, and optional ui guides in the following format:
<parameter name> : <type> <default value> /* <optional description> */ { <optional ui guides> }
Option | Description |
-plugindir <plugin directory> | Passes plugin search directory. If not specified, the directory './plugins' is used by default. More than one directory can be specified, separated by ';' (on Windows) or ':' (on Linux). The environment variable VRAY_PLUGINS_x64 can be used to specify additional plugin paths. |
-listByCategory | Lists plugins by categories. |
-pluginInterface <interface id/name> | Processes plugins that support only specified interface. Valid interface names are: EXT_BITMAP, EXT_BSDF, EXT_GEOM_GEN, EXT_GEOM_PARTICLE_DATA, EXT_LIGHT, EXT_LIGHT_LINKER, EXT_LIGHT_LIST, EXT_MAPPED_SURFACE, EXT_MATERIAL, EXT_REFERENCED_SURFACE, EXT_RENDER_CHANNEL, EXT_RENDER_VIEW, EXT_STATIC_GEOM_SOURCE, EXT_TEXTURE, EXT_TEXTURE_FLOAT, EXT_TEXTURE_INT, EXT_TEXTURE_MATRIX, EXT_TEXTURE_TRANSFORM, EXT_TEXTURE_VECTOR, EXT_UVWGEN, EXT_VOLUMETRIC, EXT_VRAY_PER_PARTICLE_DATA |
-json | Displays plugin description in JSON format. If plugin name is given, only formatting for that plugin is generated; otherwise all plugins are formatted. When -outputDir is given, JSON formatting for each plugin is saved in a separate file in that directory. The file should be saved as '<plugin name>.json', otherwise output is passed to the standard output. |
-html | Generates HTML documentation. |
-htmlOutput|-outputDir <output directory> | Sets output directory for HTML/JSON formatting. |
-id | Displays unique plugin identifier. |
-interfaces | Displays supported interfaces. |
-lib | Displays path to the plugin shared library. |
-ui | Displays UI guides for plugin parameters. |
-paramName <param name> | Searches for parameters that match specified string (supports the wildcard symbol '*'). |
-input <param type> | Displays input parameters of a given type. If plugin is not specified, all plugins with such input parameter type are displayed. Valid input types are: integer, float, double, bool, vector, color, acolor, matrix, transform, string, plugin, acolor texture, float texture, integer texture, vector texture, matrix texture, transform texture, any |
-output <param type> | Displays output parameters of a given type. If plugin is not specified, all plugins with such output parameter type are displayed. Valid output types are: transform, acolor texture, float texture, integer texture, vector texture, matrix texture, transform texture, any. |
-printRawData | Prints only raw data with additional info (suitable for 'pipes'). |
