This page provides information on the Raw Sheen Reflection Render Element.
The Sheen Render element is analogous to the Raw Reflection Render Element; the main difference is that all Sheen render elements can be subtracted from the main back-to-beauty composite, graded, and added back in.
UI Path: ||V-Ray|| > Render Elements > Raw Sheen Reflection
How to add a render element to a scene
Properties
Enable Deep OutputSpecifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post-render color adjustments made from the VFB.
