This page provides information on the Raw Coat Filter Render Element.
The Raw Coat Filter Render Element is similar to the Coat Filter Render Element, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of reflection.
UI Path: ||V-Ray|| > Render Elements > Raw Coat Filter
Properties
Enable Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Aa – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post render color adjustments made from the VFB.
