The History tab controls the render history settings such as location, amount of disk space to use and visibility parameters. Enabled – Enables/disables render history, where the V-Ray VFB keeps a history of previously rendered images. LocationUse Project Path – When enabled, creates a new vfb_history folder to use as the History Folder within the current Rhino project directory. History Folder – Specifies the location where render history images are saved as V-Ray Image files (.vrimg). Max Size on Disk (MBs) – Specifies the maximum amount of disk space to use for the render history images. When the history exceeds the specified amount, the oldest images are deleted. Auto Save – When enabled, all rendered images are automatically saved to the history. Auto Save Completed Only – When enabled, all completed rendered images are automatically saved to the history. Auto Load Layers – When enabled, loading an image from history also loads the layer tree saved with the image. Resize VFB on load – When enabled, the VFB is automatically resized to fit the loaded image. Position and ThumbnailLeft/Bottom – Specifies the position of the Render History panel. Min Thumbnail Width – Specifies the minimum width of the thumbnails in the Render History panel. You can additionally specify the image ratio for the thumbnails. Center/Fit Inside/Fit Outside – Specifies how to fit the thumbnail in the History panel. Info Font and BackgroundFont size - resolution and time – Specifies the font size of the resolution and time information on the thumbnail. Font size - note – Specifies the font size of the notes on the thumbnails. Font size - shortcut key – Specifies the font size of the 1-9 shortcut keys. Background opacity - resolution and time – Specifies the opacity of the resolution and time background. Background opacity - note – Specifies the opacity of the note background. Background opacity - compare letter – Specifies the opacity of the compare letter background. Show resolution/time – Specifies whether to show details about resolution and time of the rendered image. You can choose between Never, On History Hover, On Image Hover, and Always. Show note/name – Specifies whether to show the name/note at the bottom of the thumbnail. You can choose between Never, On History Hover, On Image Hover, and Always. Show shortcut key – Specifies whether to show shortcut keys on the rendered image thumbnail. You can choose between Never, On History Hover, On Image Hover, and Always. |
