There are some context options that V-Ray materials have. Right-click on any material in the Material's list for a context menu to appear. Search Scene – Searches the assets by name from all the categories that are selected. Use As Replacement – Select a material to use as a replacement for any other material in the scene. Select Objects In Scene – Allows selection and multi-selection of components and groups in the viewport. Replace All References – Replaces all references of a material with the preselected one. For example, a Generic material is used as part of Two Sided and Multi Material. Replace All References overwrite the Generic material in both Two Sided and Multi Material. Replace In Scene – Replaces the selected material with a preselected one. Tag – Lets you put tags on the selected material. The Asset lists have some additional multi-selection functionalities: - Ctrl on deselected item - Adds to the selection;
- Ctrl on selected item - Removes it from the selection;
- Ctrl + A - Selects all items in the list/category;
- Shift + Left-click - expands the range of the current selection;
- Click + Drag - Leaves only the clicked item selected;
- Right-Click on deselected item - Shows the context menu for the item, selects the item and deselects all other items;
- Right-Click on selected item - Shows the context menu for the item and doesn't change the selection.
