Enables/ disables the layer in the stack. Note that this is the layer you add vie the Add Layer button. Material – Specifies the coat layer material. Blend – Specifies how much of the final result is contributed by the corresponding coating material, and the rest of the materials below it. If the Blend amount is white, the final result is comprised of the coat material only, and other materials below it are blocked. If the Blend amount is black, a coat material has no effect on the final result. This parameter can also be controlled by a texture map. Blend Tex Mult – Specifies a multiplier for the amount that the texture is blended with the Blend color. |
