Color Cells – Controls the color of the cells. All parameters in this section can use a texture map, as long as the checkbox is enabled. Color Creases – Controls the color of the creases. Size – Controls the size of the procedural texture. Density – Controls how close the cells are placed next to each other. Threshold – Controls the transition between the Cell Color and Crease Color. Spottiness – Controls how circular the cells appear. Randomness – Controls how randomly the cells look in relation to each other. Defined Creases – Enables and disables creases. Color Manipulation
Invert Texture – Inverts the RGB texture values. Alpha from Intensity – Uses the texture RGB intensity/luminance as alpha channel. Color Gain – Corrects the color of the texture by multiplying the the RGB color values in the texture with the RGB color values specified here. A texture map can be assigned here. Color Offset – Corrects the color of the texture by adding the RGB color values specified here to the RGB color values in the texture. A texture map can be assigned here. Default Color – Specifies a default color used for polygons with no valid UVs. In case the map is not tiled, specifies a default color that is used outside the texture square. When a texture is selected, it overrides the color as long as the texture checkbox is enabled. |
