Line Shift – Controls the amount of shift between each line of tiles. Random Shift – Randomizes the shift. Row Modify
Row Modify – When enabled, the custom parameters are used. Per Row – Specifies which rows get the number of tiles modified by the Change parameter. Change – Changes the number of tiles for the rows specified. Smaller values increase the number of tiles. Column Modify
Column Modify – When enabled, the custom parameters are used. Per Column – Specifies which columns get the number of tiles modified by the Change parameter. Change – Changes the number of tiles for the columns specified. Smaller values increase the number of tiles. |
