Color A – Controls the first color of the Smoke procedural texture. When a texture is selected, it overrides the color as long as the texture checkbox is enabled. Color B – Controls the second color of the Smoke procedural texture. When a texture is selected, it overrides the color as long as the texture checkbox is enabled. Size – Controls the scale of the procedural texture. Iterations – Controls how many times the procedural repeats the process. Exponent – Controls the contrast of the smoke texture. Phase – Shifts the turbulence within the smoke pattern. Color Manipulation
Invert Texture – Inverts the RGB texture values. Alpha from Intensity – Uses the texture RGB intensity/ luminance as alpha channel. Color Gain – Corrects the color of the texture by multiplying the RGB color values in the texture with the RGB color values specified here. When a texture is selected, it overrides the color as long as the texture checkbox is enabled. Color Offset – Corrects the color of the texture by adding the RGB color values specified here to the RGB color values in the texture. When a texture is selected, it overrides the color as long as the texture checkbox is enabled. Default Color – Specifies a default color used for polygons with no valid UVs. In case the map is not tiled, specifies a default color that is used outside the texture square. When a texture is selected, it overrides the color as long as the texture checkbox is enabled. |
