Quantity – Chooses which lighting information to be analyzed. Illuminance (lx) – Uses the Illuminance of the rendered frame in lux. Luminance (cd) – Uses the Luminance of the rendered frame in candelas. Minimum Value – Specifies which values are mapped to blue. Maximum Value – Specifies which values are mapped to red. Scale – Specifies how values are mapped to colors onto the frame. Linear – The colors are mapped in linear scale. Logarithmic – The colors are mapped in logarithmic scale. Display Mode – Specifies the analyzed data display mode. False colors – Fills the frame with a gradient ranging from blue (low values) to red (high values). For the out of range values,it uses respectively black and white. Grid overlay – Displays the values at distinct grid points over the frame. They use the same grading colors. Draw Legend – When enabled, shows a legend of the false colors at the bottom of the render. |
