Overall Color - a common color multiplier for all color components in the material (except for opacity). Used to easily change the look of the entire hair material. Transparency - controls the transparency of the material. Diffuse Color - controls the diffuse component of the shader. Use this for materials made out of cloth threads or other non-translucent fibers, as well as for dirty hair. Note that clean hair or fur does not normally have a diffuse component, so in that case leave the parameter black. Diffuse Amount - the amount for the diffuse component of the material. Primary Specular - the primary specular color component. Normally this is dark gray. Primary Specular Amount - a multiplier for the primary specular color. Primary Glossiness - the glossiness for the primary specular component. Values closer to 1.0 make the hair more shiny and sleek. Lower values give it a matted look. Secondary Specular - the color of the secondary specular component. If Lock to Secondary is enabled, this value is ignored and the secondary specular color is derived from the transmission color. Secondary Specular Amount - a multiplier for the secondary specular component. If Lock to Secondary is enabled, this value is ignored and the secondary specular amount is derived from the transmission amount. Secondary Glossiness - the glossiness for the secondary specular component. Values closer to 1.0 correspond to shiny and sleek hair. Lower values correspond to matted hair. Transmission - the color for the transmission component. When Lock to Transmission is enabled, this color determines the overall hair color. Transmission Amount - the amount of the transmission component. Transmission Glossiness Length - the glossiness of the transmission along the hair strand length. See the Examples for a demonstration of the effect of this parameter. Transmission Glossiness Width - the glossiness for the transmission component across the hair strand width. See the Examples for a demonstration of the effect of this parameter. The transmission component of the Hair 3 material is stored in the Refraction render element. |
