File Path – Specifies the VRScene file. Lights – When enabled, lights from the imported VRScene will illuminate the current scene. Use Mtl Override – When enabled, the global Material Override option in the Render Settings overrides the .vrscene proxy assets. When disabled, the materials in the referenced scene are not affected by the Material Override option in the Render Settings. AnimationThe Animation rollout settings are not supported yet in Revit. |
Enabled () – Turns the Animation on and off. Offset – Offsets the beginning of the animation by the given number of frames. You can use positive as well as negative values here. The default value of 0.0 starts the animation at the first available frame. Playback Type – Determines how playback will behave. Loop – The animation plays to the end and loops back to the first frame once it has finished. Once – The animation plays once. Ping-pong – The animation is looped by playing it backwards once the last frame has been reached and then playing it forward again when the first frame is reached again. Playback Speed – Specifies the pace at which the animation will play. The default value of 1.0 plays the animation at normal speed (i.e. the speed for which the animation was created), while 2.0 plays it at double speed and 0.5 plays it at half speed. Animation Frame – Specifies the frame used for the beginning of the animation. Animation Length – Specifies the number of frames used to play the animation. |
