The History tab controls the render history settings such as location, amount of disk space to use and visibility parameters. Some of the options are available only when Show Advanced Settings is enabled. Enabled– Enables/disables render history, where the V-Ray VFB keeps a history of previously rendered images. LocationUse Project Path – When enabled, creates a new vfb_history folder to use as the History Folder within the current 3ds Max project directory. History Folder – Specifies the location where render history images are saved as V-Ray Image files (.vrimg). Save – Opens a browser to search for a History Folder. Recent – Shows a list of recently used locations for saved render history images. Max Size on Disk (MBs) – Specifies the maximum amount of disk space to use for the render history images. When the history exceeds the specified amount, the oldest images are deleted. Auto Save – When enabled, all rendered images are automatically saved to the history. Auto Save Completed Only – When enabled, all completed rendered images are automatically saved to the history. Auto Load Layers – When enabled, loading an image from history also loads the layer tree saved with the image. Position and ThumbnailLeft/Bottom – Specifies the position of the Render History panel. Min Thumbnail Width – Specifies the minimum width of the thumbnails in the Render History panel. You can additionally specify the image ratio for the thumbnails. Center/Fit Inside/Fit Outside – Specifies how to fit the thumbnail in the History panel. Info Font and BackgroundFont size - resolution and time – Specifies the font size of the resolution and time information on the thumbnail. Font size - note – Specifies the font size of the notes on the thumbnails. Font size - shortcut key – Specifies the font size of the 1-9 shortcut keys. Background opacity - resolution and time – Specifies the opacity of the resolution and time background. Background opacity - note – Specifies the opacity of the note background. Background opacity - compare letter – Specifies the opacity of the compare letter background. Show resolution/time – Specifies whether to show details about resolution and time of the rendered image. You can choose between Never, On History Hover, On Image Hover, and Always. Show note/name – Specifies whether to show the name/note at the bottom of the thumbnail. You can choose between Never, On History Hover, On Image Hover, and Always. Show shortcut key – Specifies whether to show shortcut keys on the rendered image thumbnail. You can choose between Never, On History Hover, On Image Hover, and Always. |
