This is a V-Ray application that is common across all V-Ray installations.
The VRImg to OpenEXR converter is both a command-line utility and a simple GUI application that can convert .vrimg image files to .exr files in OpenEXR format. The .vrimg file format stores the rendered image with all available render elements. The V-Ray Image to EXR Converter converts .vrimg files to EXR format so the render elements may be loaded into a compositing software, where they can be used for Back-to-Beauty compositing or for other adjustments and fine-tuning at the render element level.
Cinema 4D Installation
This tool comes with the V-Ray for Cinema 4D installation. You can start it from the shortcut in Windows Start > Chaos Group > VRImg to OpenEXR converter or:
Windows: start the vrimg2exr executable from C:\Program Files\Maxon Cinema 4D Rnn\plugins\V-Ray\tools
macOS: start the vrimg2exr executable from Applications/Maxon Cinema 4D Rnn/plugins/V-Ray/tools
Note: nn is the Cinema 4D version.
