This page provides information about the Matte Shadow Render Element in V-Ray for Cinema 4D.
The Matte Shadows Render Element shows areas where light doesn't reach. Compare with the Raw Shadow Render Element, which gives areas of cast shadows. While technically not part of the Beauty render elements, the Matte Shadow Render Element can be used to lighten cast shadows by adding it to the Raw Light Render Element. It can also be used to assist in adding 3D elements to a background image or footage in the composite.
UI Path: ||V-Ray|| > Render Elements > Matte Shadow
Properties
Enable Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Settings window to this render element.
Consider for Aa – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post render color adjustments made from the VFB.
