Invert – Reverses the hues of the map. Clamp – When enabled, limits the values of the colors to equal or less than 1.0. Use this option when increasing the RGB Level, to prevent the map from looking self-illuminated. Note that when Clamp is on and the value of RGB Offset is above 1.0, the colors become white. Alpha from RGB Intensity – When enabled, an alpha channel is generated based on the intensity of the RGB channels in the map. Enable Color Map – Enables the use of the Color Map. Output Amount – Controls the amount of the map that is being mixed into a composite material. This parameter affects the map's saturation and alpha values. RGB Offset – Adds colors to the RGB values of the map based on the amount set by the spinner, which affects the tonal value of the colors. RGB Level – Multiplies the RGB values of the map colors by the amount set by the spinner, which affects the saturation of the color. Bump Amount – Adjusts the bumpiness amount when the map is used as a bump map. |
