Material ID Color render element creates a mask based on the material ID Color parameter. To add the render element, you first need to add Material ID attribute from the Add Attribute button ( ) to the material. Opacity color and textures are supported by the Material ID Color channel. This render channel is useful in a compositing process as a color mask for different materials in the scene. |
