This page provides information on the Phoenix FD Deadline Simulation window.
The Deadline Simulation window is used to submit Phoenix FD simulations to Deadline.
UI Path: ||Phoenix FD menu|| > Submit Simulation to Deadline...
The path to the Phoenix scripts must be provided within the following window. The path is set by default to the correct values, so it should be changed only if you need to provide your own scripts.
When a simulation is submitted to Deadline, the selected Phoenix simulators in the scene will be simulated in the order they were selected. If no simulators are selected in the scene, all simulators will be simulated.
Deadline Repository – Specifies location of the Repository, the global file system component used by Deadline.
Simulation Script Location – Specifies the location of the Phoenix FD simulation script. This path is set by default.
