From 3ds Max 2022 the format for plugins is changed to the Autodesk Application Plug-in Package format as described here: Autodesk application package help
V-Ray for 3ds Max installation has been modified to support plugin packages.
The V-Ray installation location could be obtained by 3rd parties through the 3ds Max’s PluginPackageManager. The upgradeCode is "{00B38902-1C59-405A-875E-A9E3461F1FE7}"
Structure of the V-Ray application plugin package
For the sake of portability V-Ray for 3ds Max is installed in a single directory under the application plug-ins location, known further as PKGROOT. The accompanying V-Ray Standalone files are there too. The package is in a directory named “VRay3dsMax<3ds Max version>”. This should allow for distribution by just copying the whole package and setting the environment variables.
There are two possible locations for installing an Autodesk application package as follows:
%ALLUSERSPROFILE%\Autodesk\ApplicationPlugins\[plugin_name]
Example:
C:\ProgramData\Autodesk\ApplicationPlugins\VRay3dsMax2022
This is the preferred install location when a plug-in is installed by the Autodesk store installer. Plug-ins installed to this location are available to all users on the machine.
%APPDATA%\Autodesk\ApplicationPlugins\[plugin_name]
Example:
C:\Users\<username>\AppData\Roaming\Autodesk\ApplicationPlugins\MyPlugin
The V-Ray SDK, example projects documentation installer and it’s logs as files not essential to rendering are still in their former place (defaulting to “C:\Program Files\ChaosGroup\V-Ray\3ds Max <3ds Max version>”) further known as INSTALLROOT.
A summary of the files bundled in the Autodesk application package for V-Ray
Package element
description
Former location
[PKGROOT]/amg
viewport shaders
<Program Files>\Autodesk\3ds Max*\AMG
[PKGROOT]/assets
files needed for V-Ray for 3ds Max e.g. material_preview.vrscene
<Program Files>\Chaos Group\V-Ray\3ds Max*\assets
[PKGROOT]/bin
V-Ray Standalone binaries (needed for V-Ray GPU)
<Program Files>\Chaos Group\V-Ray\3ds Max*\bin
[PKGROOT]/defaults
3ds Max defaults settings
<Program Files>\Autodesk\3ds Max*\en-US\defaults
[PKGROOT]/docs
V-Ray EULA
<Program Files>\Chaos Group\V-Ray\3ds Max*\docs
[INSTALLROOT]/docs
V-Ray SDK documentation shipped
[INSTALLROOT]/include
V-Ray SDK headers
<Program Files>\Chaos Group\V-Ray\3ds Max*\include
[INSTALLROOT]/lib
V-Ray SDK export libraries
<Program Files>\Chaos Group\V-Ray\3ds Max*\lib
[INSTALLROOT]/mdl
VRayMDL sample shaders
<Program Files>\Chaos Group\V-Ray\3ds Max*\mdl
[PKGROOT]/opensl
VRayOSL headers
<Program Files>\Chaos Group\V-Ray\3ds Max*\opensl
[PKGROOT]/plugins
V-Ray for 3ds Max plugins
<Program Files>\Autodesk\3ds Max*\Plugins
[PKGROOT]/resources
V-Ray Toolbar icons
<Program Files>\Autodesk\3ds Max*\UI_ln
[INSTALLROOT]/samples
V-Ray SDK sample projects
<Program Files>\Chaos Group\V-Ray\3ds Max*\samples
[PKGROOT]/sceneconverter
3ds Max scene converter scripts (and presets)
<Program Files>\Autodesk\3ds Max*\SceneConverter
[PKGROOT]/scripts
3ds Max startup scripts
<Program Files>\Autodesk\3ds Max*\scripts
[INSTALLROOT]/uninstall
V-Ray installer's binary, config and log
<Program Files>\Chaos Group\V-Ray\3ds Max*\uninstall
[INSTALLROOT]/utils
Other products installations that are bundled with V-Ray
<Program Files>\Chaos Group\V-Ray\3ds Max*\utils
[PKGROOT]/PackageContents.xml
The Autodesk application package descriptor
[PKGROOT]/bin/vraydummy*
These are needed by 3ds Max in server mode
[PKGROOT]/bin/vrayspawner*.exe
[PKGROOT]/plugins/vray*.dll
[PKGROOT]/plugins/vfb2_qt.dll
Various .dlls that were loaded as dependencies for the plugins
