V-Ray GPU is a separate render engine, introduced by Chaos Group, that utilizes GPU hardware acceleration. You can additionally use it with your CPU or combine CPU and GPU devices for hybrid rendering. Choosing the V-Ray GPU engine changes the available settings. Refer to the V-Ray and MAXScript page for information on how to access the parameters through MAXScript. |
The Common tab contains no custom or unique V-Ray settings. For more details on the parameters found under this tab, please refer to the 3ds Max help documentation. |
||Main Toolbar|| > Render Setup button
||Rendering menu|| > Render Setup...
||Render Setup window|| > Renderer > V-Ray GPU
