SharingCategories – Select which categories of V-Ray for Revit settings to be exported or loaded. The following categories are supported: V-Ray Material - Includes all V-Ray materials saved within the project V-Ray Mapping - Includes the associations between Revit materials and V-Ray ones To import V-Ray materials properly, make sure that in both projects, the one you export from, as well as the one you import to, the corresponding Revit materials have the same names. |
Environment – Includes Environment settings, as well as Sun and Dome Light settings. Channels – Include all enabled render elements in the current scene. RPC Proxies – Include all RPC overrides with V-Ray Proxies (.vrmesh or .abc files). Camera – Includes all settings from the V-Ray Camera Settings dialog. Swarm – Includes all distributed rendering settings: Swarm on/off, Goal (resource usage), Auto-Discovery on/off, Coordinator IP, Tags. Export – Exports the selected Categories to a .xml file which can be loaded further in another project. Load – Loads the selected Categories from a .xml file to the current project. The settings which had been exported to the .xml file and differ from the current project’s settings will appear in the Import List below. Users select which settings they want to import by unchecking those they do not want. Load from Project Storage – In case the Revit project is workshared, allows for loading other coworkers' settings and adopting them. Note that when you import those settings, yours will be overridden. Import – Imports the selected settings from the Import List into the current project. Discard – Clears the Import List, in case the user wants to load another .xml file. |
