UI | Native name | V-Ray plugin Name (plugin/parameter) | Support |
Generic | BRDFVRayMtl |
| Diffuse Color | diffuse |  |
Diffuse Color Texture | diffuse |  |
Diffuse Roughness | roughness |  |
Diffuse Roughness Texture | roughness |  |
| Reflection Color | reflect |  |
Reflection Color Texture | reflect |  |
Highlight Glossiness | hilight_glossiness |  |
Highlight Glossiness Texture | hilight_glossiness |  |
Reflection Glossiness | reflect_glossiness |  |
Reflection Glossiness Texture | reflect_glossiness |  |
Fresnel | fresnel |  |
Reflection IOR | fresnel_ior |  |
Reflection IOR Texture | fresnel_ior |  |
Metalness | metalness |  |
Metalness Texture | metalness |  |
GGX Tail Falloff | gtr_gamma |  |
Surface Control: Use Glossiness Use Roughness | option_use_roughness=0 option_use_roughness=1 |
BRDF Type: Phong Blinn Ward Microfacet GTR (GGX) | brdf_type=0 brdf_type=1 brdf_type=2 brdf_type=4 |
Back Side Reflect | option_reflect_on_back |  |
Max Depth | reflect_depth |  |
Affect Channels: Color only Color+alpha All Channels | reflect_affect_alpha=0 reflect_affect_alpha=1 reflect_affect_alpha=2 |
Trace Reflections | reflect_trace |
| Anisotropy(-1 to 1) | anisotropy |  |
Anisotropy Texture | anisotropy |  |
Rotation | anisotropy_rotation |  |
Rotation Texture | anisotropy_rotation |  |
Derivation: Local axis Map channel | anisotropy_derivation=0 anisotropy_derivation=1 |
Local Axis: X Y Z |
anisotropy_axis=0 anisotropy_axis=1 anisotropy_axis=2 |
Map Channel/Set | anisotropy_uvwgen | |
| Dim Distance enabled | reflect_dim_distance_on |  |
Dim Distance | reflect_dim_distance |  |
Dim Falloff | reflect_dim_distance_falloff |  |
| Refraction Color | refract |  |
Refraction Color Texture | refract |  |
Fog Color | fog_color | |
Fog Color Texture | fog_color |  |
Fog Multiplier | fog_mult | |
Fog Bias | fog_bias | |
IOR | refract_ior |  |
IOR Texture | refract_ior |  |
Refraction Glossiness | refract_glossiness |  |
Refraction Glossiness Texture | refract_glossiness |  |
Affect Shadows | refract_affect_shadows |  |
Fog Units Scaling | fog_unit_scale_on |  |
Max depth | refract_depth |  |
Affect Channels: Color only Color+alpha All Channels | refract_affect_alpha=0 refract_affect_alpha=1 refract_affect_alpha=2 |
Trace Refractions | refract_trace |
| Dispersion | dispersion_on |  |
Abbe | dispersion |  |
| Fog Scattering | translucency |  |
Type: Hard (wax) model Hybrid Back-side Color Scatter Coeff Thickness Light Multiplier | translucency=1 translucency=3 translucency_color translucency_scatter_coeff translucency_thickness translucency_light_mult |
Back-side Color | translucency_color |  |
Back-side Color Texture | translucency_color |  |
Scatter Coeff | translucency_scatter_coeff |  |
Fwd/back Coeff | translucency_scatter_dir |  |
Thickness | translucency_thickness |  |
Light Multiplier | translucency_light_mult |  |
| Coat Amount | coat_amount |  |
Coat Amount Texture | coat_amount |  |
Coat Color | coat_color |  |
Coat Color Texture | coat_color |  |
Coat Glossiness | coat_glossiness |  |
Coat Glossiness Texture | coat_glossiness |  |
Coat IOR | coat_ior |  |
Coat IOR Texture | coat_ior |  |
| Coat Bump Enabled | coat_bump_lock |  |
Coat Bump Mode: Bump Map Bump Texture Channel Normal Map | coat_bump_type=0 coat_bump_type=5 coat_bump_type=1 |
Coat Bump Map Texture | coat_bump_map |
Coat Bump Amount | coat_bump_amount |  |
Coat Bump Amount Texture | coat_bump_amount |  |
| Sheen Color | sheen_color |  |
Sheen Color Texture | sheen_color |  |
Sheen Glossiness | sheen_glossiness |  |
Sheen Glossiness Texture | sheen_glossiness |  |
| Opacity | opacity |
Opacity Texture | opacity | 1
Custom Source: DIffuse Texture Alpha Opacity Texture Alpha | opacity/TexCombineFloat opacity/TexAColorChannel/mode=3 |
Mode: Normal Clip Stochastic | opacity_mode=0 opacity_mode=1 opacity_mode=2 |
1
| Bump Mode: Bump Map Normal Map | bump_type=0 bump_type=1 |
Bump Map Texture | bump_map |
Bump Amount | bump_amount |
Bump Amount Texture | bump_amount |
| Mode: Multiply Blend amount | TexCombineColor/color TexCombineColor/texture_multiplier |
Color | diffuse/TexCombineColor/texture_multiplier |
Reflection Color | reflect/TexCombineColor/texture_multiplier |
Reflection Glossiness | reflect_glossiness/TexCombineColor/texture_multiplier |
Refraction Color | refract/TexCombineColor/texture_multiplier |
IOR | refract_ior/TexCombineColor/texture_multiplier |
Refraction Glossiness | refract_glossiness/TexCombineColor/texture_multiplier |
Opacity | opacity/TexCombineColor/texture_multiplier |
| Emissive | BRDFLight | |
| Color | color |  |
Color Texture | color |  |
Intensity | colorMultiplier |  |
Intensity Texture | colorMultiplier |  |
Transparency | transparency |  |
Transparency Texture | transparency |  |
Emit On Back Side | doubleSided |  |
Compensate EV | compensateExposure |  |
Color*Opacity | multiplyByOpacity |  |
Color | TexCombineColor |  |
Intensity | TexCombineColor |  |
Transparency | TexCombineColor |  |
| Bump | BRDFBump | |
| Base | base_brdf |  |
| Map: Bump Map Bump Texture Channel Normal Map | bump_tex_color map_type=0 map_type=5 map_type=1 |
Normal Map Type: Tangent Space Object Space Screen Space World Space | map_type=1 map_type=2 map_type=3 map_type=4 |
Amount | bump_tex_mult_tex |  |
Delta Scale | bump_delta_scale |  |
