Exposure Mode – Specifies the exposure method. Gain – In this mode, the Brightness value is a simple multiplier for the input colors. F-Stops – In this mode, the Brightness value multiplies the color intensity with photographic F-stop exposure. Increasing the Brightness by one doubles the brightness, the same as increasing the Gain by 2. For example, this mode's input value of 1.0 and Brightness of 0.0 equals 1.0 (i.e., no brightness correction). Then, Brightness 1.0 corrects the input of 1.0 to equal 2, Brightness 2.0 corrects the input of 1.0 to equal 4.0, Brightness 3.0 corrects the input of 1.0 to equal 8.0, and so on. The input is multiplied by 2 to the power of the brightness value in this mode (<input> * 2 ^ <F-Stop Brightness>). Printer Lights – When set with the same value as the Printer Lights Per Stop parameter is set, it doubles the luminance. Brightness – Affects the brightness of the input colors based on the Exposure Mode. Gamma / Contrast – Determines a float value for the gamma and contrast multipliers. Increasing gamma decreases the contrast. Base – The base value for Gamma correction. Pixel values equal to the Base are not affected. This can be useful when gamma-correcting a texture without changing certain luminance levels. Offset – Adds a uniform offset to all pixel values. Use Red/ Green/ Blue – When enabled, uses the corresponding component for the advanced RGB parameters. RGB Brightness – Adjusts the brightness of the RGB channels. RGB Contrast – Same as Gamma/Contrast, but for the individual R/G/B channels. RGB Base – Same as Base, but controls which pixel values in the individual R/G/B channels are unaffected by the RGB Contrast. RGB Offset – Same as Offset, but adds a uniform offset to the individual R/G/B channels. Printer Lights Per Stop – When Printer Lights Exposure Mode is used, this value specifies how many printer lights are equal to one f-stop, doubling or halving the brightness. |
